Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement
  1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Back Panel: step 1, image 2 of 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 2, image 3 of 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 3, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 3, image 2 of 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Battery: step 4, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Battery: step 4, image 2 of 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 5, image 1 of 3 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 5, image 2 of 3 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 5, image 3 of 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Daughterboard: step 6, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Daughterboard: step 6, image 2 of 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 7, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 7, image 2 of 2
    • Using the plastic opening tool, disconnect the CMOS battery from the daughterboard by pushing it out towards the direction of the CMOS battery.
  8. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 8, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the single 5 mm screw.
  9. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 9, image 1 of 1
    • Using the iFixit Opening tool, remove the silver piece of tape from the device.
  10. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 10, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: step 10, image 2 of 2
    • Lift the daughterboard up and out of the device.
Justin Ogihara
30,247 Reputation
52 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 616
