Introduction
This guide will show you how to remove the cover. This is a prerequisite guide for all other replacement guides on this page. It is also useful if you need to clean out dust that may be causing overheating.
Remove the eight 6 mm PH0 screws highlighted using a Phillips #0 screwdriver.
Remove the two 11 mm PH0 screws highlighted using a Phillips #0 screwdriver.
Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
Follow along the back edge with the plastic opening tool, lifting the cover off. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
