Lenovo IdeaPad Flex 4-1470 Removing the Lower Case
  1. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case, Lower Case: step 1, image 1 of 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: step 2, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: step 2, image 2 of 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
6 other people completed this guide.
Demario Robinson
1,038 Reputation
4 Guides authored
USF Tampa, Team S1-G6, Thompson Fall 2017 Member of USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Members
10 Guides authored
One Comment
can someone please tell me where to find the back cover? i need to order it
angel etoile - Reply
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 73
All Time: 19,152
