Installing Lenovo Essential G560 Back Panel
  1. Installing Lenovo Essential G560 Back Panel, Battery: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Installing Lenovo Essential G560 Back Panel: step 2, image 1 of 2 Installing Lenovo Essential G560 Back Panel: step 2, image 2 of 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Installing Lenovo Essential G560 Back Panel: step 3, image 1 of 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Installing Lenovo Essential G560 Back Panel, Back Panel: step 4, image 1 of 1
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
  5. Installing Lenovo Essential G560 Back Panel: step 5, image 1 of 2 Installing Lenovo Essential G560 Back Panel: step 5, image 2 of 2
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. Installing Lenovo Essential G560 Back Panel: step 6, image 1 of 1
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
Lawrence Downs
383 Reputation
2 Guides authored
Cal Poly, Team 18-40, Regan Winter 2013 Member of Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 4,841
