Introduction
This guide will show you how to replace the screen on a Lenovo ThinkPad Edge E431 laptop.
Remove the 2mm Phillips #00 screw from the battery cover.
Lift the battery cover out of its slot.
Use the pointed end of a spudger to remove the two screw covers from the bottom corners of the display.
Carefully remove the adhesive tape.
To disconnect the ZIF (zero insertion force) connector, the user will need to unlock the small flap by either using a metal tweezers or your fingernail. After which, the cable can be safely pulled out.
