Lenovo Edge Thinkpad E431 Screen Replacement
  1. Lenovo Edge Thinkpad E431 Screen Replacement, Battery: step 1, image 1 of 2 Lenovo Edge Thinkpad E431 Screen Replacement, Battery: step 1, image 2 of 2
    • Remove the 2mm Phillips #00 screw from the battery cover.
    • Lift the battery cover out of its slot.
  2. Lenovo Edge Thinkpad E431 Screen Replacement: step 2, image 1 of 1
    • Disconnect the battery cable.
  3. Lenovo Edge Thinkpad E431 Screen Replacement, Screen: step 3, image 1 of 1
    • Use the pointed end of a spudger to remove the two screw covers from the bottom corners of the display.
  4. Lenovo Edge Thinkpad E431 Screen Replacement: step 4, image 1 of 1
    • Remove the two 2mm Phillips #00 screws found at the bottom corners of the display.
  5. Lenovo Edge Thinkpad E431 Screen Replacement: step 5, image 1 of 1
    • Separate the front bezel from the display using the plastic opening tool.
  6. Lenovo Edge Thinkpad E431 Screen Replacement: step 6, image 1 of 1
    • Remove the four 2mm Phillips #00 screws from the screen.
  7. Lenovo Edge Thinkpad E431 Screen Replacement: step 7, image 1 of 2 Lenovo Edge Thinkpad E431 Screen Replacement: step 7, image 2 of 2
    • Lay the screen flat on top of the keyboard.
  8. Lenovo Edge Thinkpad E431 Screen Replacement: step 8, image 1 of 2 Lenovo Edge Thinkpad E431 Screen Replacement: step 8, image 2 of 2
    • Peel up the adhesive tape to unlatch the metal retaining bracket on the display cable.
3 other people completed this guide.
USF Tampa, Team S3-G3, Nance Spring 2018 Member of USF Tampa, Team S3-G3, Nance Spring 2018
USFT-NANCE-S18S3G3
4 Members
6 Guides authored
1 Guide Comment
Where do I buy the screen
Link - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 16
All Time: 1,829
