LeapFrog LeapPad2 Explorer Back Cover Replacement
  1. LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: step 1, image 2 of 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Cover Replacement: step 2, image 1 of 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: step 2, image 2 of 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: step 2, image 3 of 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: step 3, image 1 of 2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: step 3, image 2 of 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Cover Replacement: step 4, image 1 of 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: step 4, image 2 of 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: step 4, image 3 of 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
Nupur Garg
867 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2014 Member of Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Members
16 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 11
All Time: 1,417
