Leader Impression i10A-LE Back Facing Camera Replacement
  1. Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: step 1, image 1 of 2 Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: step 1, image 2 of 2
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Back Facing Camera Replacement: step 2, image 1 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 2, image 2 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 2, image 3 of 3
    • Start by prying the back off by using plastic opening tools
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Back Facing Camera Replacement: step 3, image 1 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 3, image 2 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 3, image 3 of 3
    • Once the back is off, locate the back facing camera.
    • The camera will be in the top left corner.
    • Using the precision tweezers that are bent, gently grab the strip below the camera.
    • slowly lift up until the camera lifts from its spot.
  4. Leader Impression i10A-LE Back Facing Camera Replacement: step 4, image 1 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 4, image 2 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 4, image 3 of 3
    • Continue slowly lifting with the bent precision tweezers.
    • The bottom half of the camera strip will pop out.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 10
All Time: 203
