LG VX8700 Keypad Replacement
  1. LG VX8700 Keypad Replacement, Battery: step 1, image 1 of 2 LG VX8700 Keypad Replacement, Battery: step 1, image 2 of 2
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Keypad Replacement: step 2, image 1 of 2 LG VX8700 Keypad Replacement: step 2, image 2 of 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Keypad Replacement, Keypad: step 3, image 1 of 2 LG VX8700 Keypad Replacement, Keypad: step 3, image 2 of 2
    • Unscrew nine 4 mm screws that hold the case together using a Phillips #0 Screwdriver.
  4. LG VX8700 Keypad Replacement: step 4, image 1 of 2 LG VX8700 Keypad Replacement: step 4, image 2 of 2
    • Insert the tip of the plastic opening tool into the small notch on the side of the case.
    • Gently manipulate the tool to open the case.
  5. LG VX8700 Keypad Replacement: step 5, image 1 of 1
    • Separate the two halves of the phone.
    • On the left is the back of the phone holding the logic board and key pad.
    • On the right is the plastic casing.
  6. LG VX8700 Keypad Replacement: step 6, image 1 of 3 LG VX8700 Keypad Replacement: step 6, image 2 of 3 LG VX8700 Keypad Replacement: step 6, image 3 of 3
    • Holding the phone casing with one hand, and the key pad assembly with the other, separate the phone case from the keypad/logic board.
  7. LG VX8700 Keypad Replacement: step 7, image 1 of 2 LG VX8700 Keypad Replacement: step 7, image 2 of 2
    • Remove the key pad from the logic board by pulling the two boards apart, separating this connection.
tnscholz
18 Reputation
1 Guide authored
Cal Poly, Team 8-16, Maness Winter 2012 Member of Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 738
