Lift one side of the battery using a plastic opening tool or your fingers.
Carefully remove the battery and set it aside.
Insert the tip of the plastic opening tool into the small notch on the side of the case.
Gently manipulate the tool to open the case.
Holding the phone casing with one hand, and the key pad assembly with the other, separate the phone case from the keypad/logic board.
Remove the key pad from the logic board by pulling the two boards apart, separating this connection.
