LG VX6100 Backcase Replacement
  1. LG VX6100 Backcase Replacement, Backcase: step 1, image 1 of 1
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Backcase Replacement: step 2, image 1 of 1
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Backcase Replacement: step 3, image 1 of 1
    • Locate two gray plugs as indicated. Using a push-pin or tweezers, pry both of these plugs out.
  4. LG VX6100 Backcase Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the six screws as indicated.
  5. LG VX6100 Backcase Replacement: step 5, image 1 of 2 LG VX6100 Backcase Replacement: step 5, image 2 of 2
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
Teal
1 Reputation
2 Guides authored
Cal Poly, Team 12-39, Regan Spring 2012 Member of Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 568
