Repairing LG VX5200 Antenna
  1. Repairing LG VX5200 Antenna, Battery: step 1, image 1 of 2 Repairing LG VX5200 Antenna, Battery: step 1, image 2 of 2
    • Turn the phone on its back.
  2. Repairing LG VX5200 Antenna: step 2, image 1 of 2 Repairing LG VX5200 Antenna: step 2, image 2 of 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. Repairing LG VX5200 Antenna: step 3, image 1 of 2 Repairing LG VX5200 Antenna: step 3, image 2 of 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. Repairing LG VX5200 Antenna, LG VX5200 Rear Body Panel Disassembly: step 4, image 1 of 1
    • Orient the phone as shown with the battery already removed.
  5. Repairing LG VX5200 Antenna: step 5, image 1 of 3 Repairing LG VX5200 Antenna: step 5, image 2 of 3 Repairing LG VX5200 Antenna: step 5, image 3 of 3
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. Repairing LG VX5200 Antenna: step 6, image 1 of 3 Repairing LG VX5200 Antenna: step 6, image 2 of 3 Repairing LG VX5200 Antenna: step 6, image 3 of 3
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. Repairing LG VX5200 Antenna: step 7, image 1 of 1
    • Check to see that your device looks like the attached photo.
  8. Repairing LG VX5200 Antenna, Antenna: step 8, image 1 of 1
    • Locate the screw and copper fixture that hold the antenna in place.
    • Remove the screw from the device using a Philips #00 screwdriver.
  9. Repairing LG VX5200 Antenna: step 9, image 1 of 2 Repairing LG VX5200 Antenna: step 9, image 2 of 2
    • Remove the copper fixture after it has been unscrewed.
  10. Repairing LG VX5200 Antenna: step 10, image 1 of 2 Repairing LG VX5200 Antenna: step 10, image 2 of 2
Douglas Blaalid
282 Reputation
8 Guides authored
Cal Poly, Team 4-13, Forte Winter 2010 Member of Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Members
15 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 16
All Time: 2,453
