Introduction
A guide to replace the antenna.
Orient the phone as shown with the battery already removed.
Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
Place an iPod opener tool in the seam above the antenna.
Run the tool around the perimeter of the entire phone.
Locate the screw and copper fixture that hold the antenna in place.
Remove the screw from the device using a Philips #00 screwdriver.
