Introduction
Use this guide to replace the earpiece speaker in your LG V20.
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
Flip the phone and insert an opening pick in the gap you created.
Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
Remove the frame section.
Repeat this procedure with the frame section on the other end of the phone.
The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
Tool used on this step:Tweezers$4.99
Use the flat end of a spudger to disconnect the front camera flex cable.
Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
The second rear camera will come out with the motherboard since it is connected on the other side.
You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
Carefully lift up the motherboard assembly and remove it.
Use an iOpener to loosen the adhesive beneath the earpiece speaker and its flex cable.
Use a pair of tweezers to carefully lift the earpiece speaker out of the device and remove it.
