LG TP 1100 Microphone Replacement
  1. LG TP 1100 Microphone Replacement, Microphone: step 1, image 1 of 1
    • Hold antenna between your fingers and unscrew in a counterclockwise direction.
  2. LG TP 1100 Microphone Replacement: step 2, image 1 of 1
    • You will remove antenna by pulling it in an upward motion away from the socket.
  3. LG TP 1100 Microphone Replacement: step 3, image 1 of 1
    • Turn phone so that the back is facing you.
  4. LG TP 1100 Microphone Replacement: step 4, image 1 of 1
    • Use your thumb to pull the tab in an upward motion to release the battery.
  5. LG TP 1100 Microphone Replacement: step 5, image 1 of 1
    • Hold phone securely in one hand and pull the battery away from the phone with your other hand.
  6. LG TP 1100 Microphone Replacement: step 6, image 1 of 1
    • Use your screwdriver to unscrew the four screws from the back plate.
  7. LG TP 1100 Microphone Replacement: step 7, image 1 of 1
    • Turn phone to the side as indicated in the picture.
  8. LG TP 1100 Microphone Replacement: step 8, image 1 of 1
    • Remove the back cover that you just unscrewed and set aside.
  9. LG TP 1100 Microphone Replacement: step 9, image 1 of 1
    • Open the remaining parts like a book but do not separate the two pieces.
    • Do not tear the tape connecting the two pieces.
  10. LG TP 1100 Microphone Replacement: step 10, image 1 of 2 LG TP 1100 Microphone Replacement: step 10, image 2 of 2
    • Rotate the phone so that the circuit board is in the palm of your hand and the part connected with tape hangs behind.
    • Use your opening tool to pry the circuit board from the front cover. Do not let the number pad to fall out.
  11. LG TP 1100 Microphone Replacement: step 11, image 1 of 1
    • To remove the microphone, insert your opening tool under microphone and push upward to pry microphone away from the front cover.
Johnny Inlow
19 Reputation
3 Guides authored
Cal Poly, Team 27-91, Amido Spring 2010 Member of Cal Poly, Team 27-91, Amido Spring 2010
CPSU-AMIDO-S10S27G91
5 Members
11 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 13
All Time: 1,301
