Introduction
Use this guide to replace the display board on your LG model LFX25973 refrigerator.
The display board shows the status of your refrigerator.
If it fails, a number of features on the dispenser may not work, including the ice type selection and temperature settings.
Gaining access to the display board takes some effort. You will have to remove the dispenser assembly, which can be somewhat difficult.
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
To remove the left door handle, first open the right door.
Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
Right side clips
Top clips
Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
Use a spudger to pry out the top edge of the dispenser assembly.
Once you've created a gap, use your fingertips to pull the edge downward.
Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
Grasp the top edge of the dispenser assembly in the middle and pull outwards.
Continue prying and pulling around the perimeter of the assembly to release it.
Squeeze the two multiple wire connectors and pull them straight off to disconnect them from the display board.
Do not attempt to remove the four-wire connector from the board as it is not removable.
Use a Phillips screwdriver to remove the 11 mm‑long screw securing the white circuit board holder to the dispenser assembly.
Lift and remove the circuit board holder from the dispenser assembly.
Remove the tape securing wires to the rear of the dispenser assembly.
Pull the orange and white connector from the ice dispensing switch to disconnect it.
Use a Phillips driver to remove the eight 8 mm‑long screws securing the display board to the dispenser assembly.
