Introduction
Use this guide to replace the dispenser PC board.
The dispenser PC Board (also called the power control board, part number EBR60070707) controls a number of functions. The ice and water dispensing systems are directly tied to this board. If it fails, you will likely have no cubes or water.
This board is checked mainly by elimination. All the other parts of the ice and water dispensing systems should be checked first. There are a couple of voltage tests that you can run on this PCB if you are skilled with a multimeter. You will need to plug in your partially disassembled refrigerator to perform them, which is somewhat hazardous.
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
To remove the left door handle, first open the right door.
Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
Right side clips
Top clips
Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
Use a spudger to pry out the top edge of the dispenser assembly.
Once you've created a gap, use your fingertips to pull the edge downward.
Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
Grasp the top edge of the dispenser assembly in the middle and pull outwards.
Continue prying and pulling around the perimeter of the assembly to release it.
Squeeze the two multiple wire connectors and pull them straight off to disconnect them from the display board.
Do not attempt to remove the four-wire connector from the board as it is not removable.
Use a Phillips screwdriver to remove the 11 mm‑long screw securing the white circuit board holder to the dispenser assembly.
Lift and remove the circuit board holder from the dispenser assembly.
Push the wing of the circuit board holder cover toward the wires to release it.
Slide the circuit board holder cover off of the circuit board holder and remove it.
Squeeze and pull the first of three connectors straight off to disconnect it from the circuit board.
Use a Philips screwdriver to remove the 10 mm screw securing the circuit board to the circuit board holder.
Lift off the circuit board and remove it.
