LG Optimus V Antenna Replacement
  1. LG Optimus V Antenna Replacement, Battery: step 1, image 1 of 1
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Antenna Replacement: step 2, image 1 of 1
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Antenna Replacement: step 3, image 1 of 3 LG Optimus V Antenna Replacement: step 3, image 2 of 3 LG Optimus V Antenna Replacement: step 3, image 3 of 3
    • Gently remove the battery with your spudger.
  4. LG Optimus V Antenna Replacement, Camera: step 4, image 1 of 2 LG Optimus V Antenna Replacement, Camera: step 4, image 2 of 2
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Antenna Replacement: step 5, image 1 of 3 LG Optimus V Antenna Replacement: step 5, image 2 of 3 LG Optimus V Antenna Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Antenna Replacement: step 6, image 1 of 2 LG Optimus V Antenna Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Antenna Replacement, Antenna: step 7, image 1 of 1
    • This part circled in red is the antenna
  8. LG Optimus V Antenna Replacement: step 8, image 1 of 1
    • Solder off the antenna and solder on the new one. The antenna is now replaced.
Joseph Pasquantonio
683 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Member of UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 2,178
