Introduction
In this step-by-step guide, you will be able to successfully replace your motherboard in your LG Optimus F3 device.
Turn the device so that the back faces up.
Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
Use the plastic opening tool to separate the inner case from the device.
Wedge the plastic opening tool between the case.
Wiggle the tool and use leverage to pry the case apart.
Use the plastic opening tool to separate the camera from the motherboard.
Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
Use the plastic opening tool to remove the charging port unit.
Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
