LG Optimus F3 Charging port unit Replacement
    1. LG Optimus F3 Charging port unit  Replacement, Motherboard: step 1, image 1 of 1
      • Turn the device so that the back faces up.
      • It is easiest to open the case near the charging port located at the bottom of the phone.
      • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
      Ask FixBot
    2. LG Optimus F3 Charging port unit  Replacement: step 2, image 1 of 1
      • With back case removed, the battery is visible. The battery is the large square object.
      • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
      Ask FixBot
    3. LG Optimus F3 Charging port unit  Replacement: step 3, image 1 of 1
      • Remove 10 1.0 mm screws located on the back of the device.
      • Refer to the outlined locations in the image for the screws.
      Ask FixBot
    4. LG Optimus F3 Charging port unit  Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to separate the inner case from the device.
      • Wedge the plastic opening tool between the case.
      • Wiggle the tool and use leverage to pry the case apart.
      Ask FixBot
    5. LG Optimus F3 Charging port unit  Replacement: step 5, image 1 of 1
      • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
      • Use the plastic opening tool to separate the camera from the motherboard.
      • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
      Ask FixBot
    6. LG Optimus F3 Charging port unit  Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to disconnect and remove the rear facing camera.
      Ask FixBot
    7. LG Optimus F3 Charging port unit  Replacement: step 7, image 1 of 1
      • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
      • Note that the sim card and the memory card connector are one unit.
      • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
      Ask FixBot
    8. LG Optimus F3 Charging port unit  Replacement: step 8, image 1 of 1
      • Use the plastic opening tool to remove the charging port unit.
      • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
      Ask FixBot
    9. LG Optimus F3 Charging port unit  Replacement: step 9, image 1 of 1
      • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
      • The motherboard is an L-shaped unit above and to the left of the battery encasement.
      • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
      Ask FixBot
    1. LG Optimus F3 Charging port unit  Replacement, Charging port unit: step 10, image 1 of 1
      • Remove one 1.0 mm screw.
      Ask FixBot
    2. LG Optimus F3 Charging port unit  Replacement: step 11, image 1 of 1
      • Use a plastic opening tool to remove front glass protector.
      Ask FixBot
    3. LG Optimus F3 Charging port unit  Replacement: step 12, image 1 of 1
      • Use the plastic opening tool to remove front glass cover carefully. Try not to break the connector.
      Ask FixBot
    4. LG Optimus F3 Charging port unit  Replacement: step 13, image 1 of 1
      • Remove the front facing camera.
      Ask FixBot
    5. LG Optimus F3 Charging port unit  Replacement: step 14, image 1 of 1
      • Use the plastic opening tool to carefully remove the home button board. It is attached with double-sided tape.
      Ask FixBot
    6. LG Optimus F3 Charging port unit  Replacement: step 15, image 1 of 1
      Ask FixBot
    7. LG Optimus F3 Charging port unit  Replacement: step 16, image 1 of 1
      • You are all set.
      Ask FixBot
3 other people completed this guide.
Jonathan Fang
356 Reputation
2 Guides authored
UMass Dartmouth, Team 1-5, Miles Fall 2015 Member of UMass Dartmouth, Team 1-5, Miles Fall 2015
UMASSD-MILES-F15S1G5
3 Members
40 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 51
All Time: 972
