LG Neon GT 365 Keyboard Replacement
  1. LG Neon GT 365 Keyboard Replacement, Keyboard: step 1, image 1 of 2 LG Neon GT 365 Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • With one hand, push the rectangular button located on the back top-side of the phone.
    • With your other hand, remove the rear cover.
  2. LG Neon GT 365 Keyboard Replacement: step 2, image 1 of 1
    • Remove 5 screws, 1 from each corner of the phone and 1 from the center-right of the phone.
  3. LG Neon GT 365 Keyboard Replacement: step 3, image 1 of 2 LG Neon GT 365 Keyboard Replacement: step 3, image 2 of 2
    • Now pull off the rear casing, using an opening tool. **Buttons for volume and pictures may fall out**
  4. LG Neon GT 365 Keyboard Replacement: step 4, image 1 of 1
    • Hold the circuit board and turn the phone upside down.
    • Then let the circuit board hang down so you can disconnect the ribbon by getting under an edge and popping it off. **the rubber keyboard may fall out**
  5. LG Neon GT 365 Keyboard Replacement: step 5, image 1 of 1
    • Once the circuit board has been removed the rubber keypad will be visible. If it has not fallen out on its own it can simply be peeled out. It is lightly attached like a sticker on the top three tabs. The left most table is labeled “B”, the center tab is blank, and the right tab is labeled “N”.
kristie
538 Reputation
5 Guides authored
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G1
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 278
