Introduction
This guide will instruct you on how to replace a cracked or damaged LCD screen and digitizer assembly in your LG G4 smartphone.
It may be necessary to use a pre-cut LG G4 adhesive strip or Tesa 61395 tape to secure your new screen to your device.
Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
Detach the cover with your fingers
Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
Front-facing camera connector.
Rear-facing camera connector.
Digitizer connector.
Use a heat gun or iOpener over the auxiliary port to soften the adhesive that secures it to the plastic housing.
Tool used on this step:Spudger$2.99
Insert a nylon spudger into the auxiliary port and gently pry upward to free the port.
Use a spudger to carefully remove these components and then place them in the new display assembly..
Insert the flat side of a nylon spudger below the digitizer ribbon cable to free it from the adhesive.
Tool used on this step:Heavy-Duty Suction Cups (Pair)$14.95
Use a heavy duty suction cup and firmly pull the screen away from the frame to create a small gap.
Tool used on this step:iFixit Opening Picks (Set of 6)$4.99
Insert a plastic opening pick into the gap between the screen and the plastic housing.
Slide the plastic opening pick along the border of the screen to break any additional adhesive and free the screen assembly.
