Introduction
Use this guide to replace the rear case on your LG G Watch.
First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
Grasp the exposed shoulder with the tweezers to perform the next step.
Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Slide the opening pick between the rear case and the rest of the device to separate the two halves.
Gently pull the two halves apart.
