Introduction
If your tablet isn't working properly, you may need to replace the motherboard. This guide will show you how to replace the motherboard.
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Tool used on this step:Magnetic Project Mat$19.95
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
8 other people completed this guide.
