LG G Pad 8.3 Battery Replacement
  1. LG G Pad 8.3 Battery Replacement, Back Panel: step 1, image 1 of 2 LG G Pad 8.3 Battery Replacement, Back Panel: step 1, image 2 of 2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Battery Replacement: step 2, image 1 of 3 LG G Pad 8.3 Battery Replacement: step 2, image 2 of 3 LG G Pad 8.3 Battery Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Battery Replacement: step 3, image 1 of 2 LG G Pad 8.3 Battery Replacement: step 3, image 2 of 2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Battery Replacement, Speaker: step 4, image 1 of 2 LG G Pad 8.3 Battery Replacement, Speaker: step 4, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  5. LG G Pad 8.3 Battery Replacement: step 5, image 1 of 1
    • Use your fingers to remove the speaker.
  6. LG G Pad 8.3 Battery Replacement, Battery: step 6, image 1 of 2 LG G Pad 8.3 Battery Replacement, Battery: step 6, image 2 of 2
    • With a Philips screwdriver #000 unscrew the 3mm screws at the corners of the battery.
  7. LG G Pad 8.3 Battery Replacement: step 7, image 1 of 3 LG G Pad 8.3 Battery Replacement: step 7, image 2 of 3 LG G Pad 8.3 Battery Replacement: step 7, image 3 of 3
    • Using a spudger or plastic opening tool, disconnect the ribbon cable from the right side of the device, where it is attached with adhesive.
    • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
  8. LG G Pad 8.3 Battery Replacement: step 8, image 1 of 2 LG G Pad 8.3 Battery Replacement: step 8, image 2 of 2
    • Use the Philips screwdriver #000 to remove the 3mm screws at the bottom of the tape.
    • Remove the yellow tape from the device.
  9. LG G Pad 8.3 Battery Replacement: step 9, image 1 of 2 LG G Pad 8.3 Battery Replacement: step 9, image 2 of 2
    • Unhook the battery from where it is attached at the top of the device.
Mario Salguero
781 Reputation
6 Guides authored
CSU Fullerton, Team 1-6, Bruce Fall 2015 Member of CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Members
14 Guides authored
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 78
All Time: 44,308
