Introduction
If your battery isn't working, it may be time to replace it. This guide will show you how to replace the battery.
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Insert a plastic opening tool in the small crevasse between the screen and the back panel.
Pry the screen away from the back panel.
Repeat this on each edge of the device.
After using the plastic opening tools, pry the device open with your hands.
Remove the back panel from the screen.
Tool used on this step:Magnetic Project Mat$19.95
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
Using a Philips #000 screwdriver, unscrew the 3mm screws in the corners of the battery.
Using a spudger or plastic opening tool, disconnect the ribbon cable from the right side of the device, where it is attached with adhesive.
Use the Philips #000 screwdriver to remove the 3mm screws at the bottom of the tape.
Remove the yellow tape from the device.
