Introduction
This guide explains how to remove the back cover from your LG CG225.
Locate the screw cover on the back of the phone near the antenna. Use a Phillips #00 screwdriver to pry off the screw cover. Set the screw cover aside.
Remove the highlighted screw from the back of phone using a Phillips #00 screwdriver. Set the screw aside.
Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
