LG CG225 Rear Cover Replacement
  1. LG CG225 Rear Cover Replacement, Rear Cover: step 1, image 1 of 1
    • Locate the screw cover on the back of the phone near the antenna. Use a Phillips #00 screwdriver to pry off the screw cover. Set the screw cover aside.
  2. LG CG225 Rear Cover Replacement: step 2, image 1 of 1
    • Remove the highlighted screw from the back of phone using a Phillips #00 screwdriver. Set the screw aside.
  3. LG CG225 Rear Cover Replacement: step 3, image 1 of 1
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
Darlena
219 Reputation
3 Guides authored
Ohio State, Team 1-2, Buehl Spring 2014 Member of Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 161
