Kurio Xtreme Camera Replacement
  1. Kurio Xtreme Camera Replacement, Back Panel: step 1, image 1 of 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Camera Replacement: step 2, image 1 of 2 Kurio Xtreme Camera Replacement: step 2, image 2 of 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Camera Replacement: step 3, image 1 of 3 Kurio Xtreme Camera Replacement: step 3, image 2 of 3 Kurio Xtreme Camera Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Camera Replacement, Camera: step 4, image 1 of 1
    • Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
  5. Kurio Xtreme Camera Replacement: step 5, image 1 of 3 Kurio Xtreme Camera Replacement: step 5, image 2 of 3 Kurio Xtreme Camera Replacement: step 5, image 3 of 3
    • Remove the smaller, front facing camera by lifting up on the attached ribbon cable.
    • Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
Mallory Myers
1,190 Reputation
7 Guides authored
Baylor, Team 6-10, Williams Fall 2015 Member of Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 176
