Krups F203 Coffee Grinder Motor Replacement
  1. Krups F203 Coffee Grinder Motor Replacement, Base Plate: step 1, image 1 of 1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Motor Replacement: step 2, image 1 of 3 Krups F203 Coffee Grinder Motor Replacement: step 2, image 2 of 3 Krups F203 Coffee Grinder Motor Replacement: step 2, image 3 of 3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Motor Replacement: step 3, image 1 of 2 Krups F203 Coffee Grinder Motor Replacement: step 3, image 2 of 2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Motor Replacement, Detach Trigger Button from Base Plate: step 4, image 1 of 1
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Motor Replacement: step 5, image 1 of 2 Krups F203 Coffee Grinder Motor Replacement: step 5, image 2 of 2
    • Remove the white trigger.
  6. Krups F203 Coffee Grinder Motor Replacement: step 6, image 1 of 1
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
  7. Krups F203 Coffee Grinder Motor Replacement, Motor: step 7, image 1 of 1
    • Desolder remaining contact point from the plug cord
  8. Krups F203 Coffee Grinder Motor Replacement: step 8, image 1 of 2 Krups F203 Coffee Grinder Motor Replacement: step 8, image 2 of 2
    • Using a Phillips screwdriver, remove the two screws holding the motor in place.
  9. Krups F203 Coffee Grinder Motor Replacement: step 9, image 1 of 1
    • Remove the motor from the shell.
Ian Hancock
414 Reputation
3 Guides authored
Baylor, Team 4-2, Williams Fall 2014 Member of Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 Members
8 Guides authored
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 119
All Time: 27,294
