Krups 963 Power Switch Replacement
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: step 1, image 1 of 1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Switch Replacement: step 2, image 1 of 1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Switch Replacement: step 3, image 1 of 1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Switch Replacement, Power Switch: step 4, image 1 of 1
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  5. Krups 963 Power Switch Replacement: step 5, image 1 of 1
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
Wyatt Hall
842 Reputation
7 Guides authored
Cal Poly, Team 6-25, Maness Fall 2014 Member of Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 Members
7 Guides authored
One Comment
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 3,029
