Shop the Holiday Gift Guide
Krups 963 Bottom Panel Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
7
All Time:
194
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite Only
Tools
    1. Krups 963  Bottom Panel Removal, Removing Bottom Screws: step 1, image 1 of 1
      • Make sure the device is unplugged before continuing.
      • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
      Ask FixBot
    2. Krups 963  Bottom Panel Removal: step 2, image 1 of 1
      • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
      Ask FixBot
    3. Krups 963  Bottom Panel Removal: step 3, image 1 of 1
      • Remove the bottom cover from the machine and slide it down the power cord.
      Ask FixBot
Author
with
Wyatt Hall
866 Reputation
7 Guides authored
Cal Poly, Team 6-25, Maness Fall 2014 Member of Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 194
