Kodak PIXPRO WPZ2 Battery Replacement
    1. Kodak PIXPRO WPZ2 Battery Replacement, Battery: step 1, image 1 of 3 Kodak PIXPRO WPZ2 Battery Replacement, Battery: step 1, image 2 of 3 Kodak PIXPRO WPZ2 Battery Replacement, Battery: step 1, image 3 of 3
      • Turn the camera upside down to locate the battery compartment.
      • Slide the battery door latch to the unlock position.
      • The door should spring open.
      • Lift the door open to access the battery compartment.
      Ask FixBot
    2. Kodak PIXPRO WPZ2 Battery Replacement: step 2, image 1 of 1
      • Push the yellow release lever beside the battery compartment to the side.
      • The battery will spring up slightly.
      • Pull the battery from the compartment.
      • Place the new battery into the compartment with the metal contacts facing the metal connectors inside. Push the battery down until it clicks under the release lever. Close the battery door and slide the latch to lock it.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Nafeesa Shameem
135 Reputation
1 Guide authored
Texas Tech, Team 37-4, Allen Fall 2025 Member of Texas Tech, Team 37-4, Allen Fall 2025
TTU-ALLEN-F25S37G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 91
All Time: 625
