Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
Remove the silver band.
Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
Remove the Worm Gear.
Before replacing part, make sure you remove all the old grease (the black gunk). It could contain metal shards that will quickly wear down gears. I used a 50% alcohol and a lot of rags and cotton swabs (Q-Tips®). Make sure everything is dry before placing new food-grade grease.
How do I know the code of this part?
Kirtchen Aid Store Part Nr. KitchenAid W10112253 481201230741
VauWeh -
This part probably fits, but you have to check carefully.
VauWeh -
The parts nr is not correct! Does anybody have the correct nr?
Is there a part number for the two metal stand off guide things on the worm gear?
9 other people completed this guide.
Maybe start with unplugging it ?
Ryan F - Reply
