Kindle Touch Screen Replacement
  1. Kindle Touch Screen Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch Screen Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch Screen Replacement, Back Cover: step 1, image 3 of 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
  2. Kindle Touch Screen Replacement: step 2, image 1 of 2 Kindle Touch Screen Replacement: step 2, image 2 of 2
    • Gently lift the bottom and slide the panel off.
  3. Kindle Touch Screen Replacement, Battery: step 3, image 1 of 3 Kindle Touch Screen Replacement, Battery: step 3, image 2 of 3 Kindle Touch Screen Replacement, Battery: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Screen Replacement: step 4, image 1 of 3 Kindle Touch Screen Replacement: step 4, image 2 of 3 Kindle Touch Screen Replacement: step 4, image 3 of 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch Screen Replacement, Remove the 3G Board: step 5, image 1 of 3 Kindle Touch Screen Replacement, Remove the 3G Board: step 5, image 2 of 3 Kindle Touch Screen Replacement, Remove the 3G Board: step 5, image 3 of 3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
  6. Kindle Touch Screen Replacement, Bezel: step 6, image 1 of 2 Kindle Touch Screen Replacement, Bezel: step 6, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  7. Kindle Touch Screen Replacement: step 7, image 1 of 3 Kindle Touch Screen Replacement: step 7, image 2 of 3 Kindle Touch Screen Replacement: step 7, image 3 of 3
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
  8. Kindle Touch Screen Replacement, Rear Casing: step 8, image 1 of 1
    • Use your Phillips #00 srewdriver to remove the indicated screws.
    • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
  9. Kindle Touch Screen Replacement: step 9, image 1 of 2 Kindle Touch Screen Replacement: step 9, image 2 of 2
    • With the screws removed, gently remove the case from the internals.
  10. Kindle Touch Screen Replacement, Motherboard: step 10, image 1 of 3 Kindle Touch Screen Replacement, Motherboard: step 10, image 2 of 3 Kindle Touch Screen Replacement, Motherboard: step 10, image 3 of 3
    • With the screen facing you, use your heated iOpener or other heating element to loosen the glue holding the WiFi unit to the screen. After 30 seconds, remove the heating element.
    • After the glue is loosened, use a thin tool, like a Spudger or small plastic opening tool, to separate the WiFi unit from the screen.
  11. Kindle Touch Screen Replacement: step 11, image 1 of 2 Kindle Touch Screen Replacement: step 11, image 2 of 2
    • With the motherboard facing you, use the pointy end of your Spudger to gently separate the two speaker's connectors.
    • This connector type requires being lifted out of place, not pulled. Accidentally pulling may damage the wires.
    • During reassembly, make sure the speaker's connectors are not pushed behind the motherboard.
    • Use your #00 Phillips Screwdriver to remove the seven 2 mm screws.
  12. Kindle Touch Screen Replacement: step 12, image 1 of 3 Kindle Touch Screen Replacement: step 12, image 2 of 3 Kindle Touch Screen Replacement: step 12, image 3 of 3
    • Use a Spudger to separate the display's connector from the motherboard.
    • Gently remove the motherboard from the display support.
  13. Kindle Touch Screen Replacement, Screen: step 13, image 1 of 3 Kindle Touch Screen Replacement, Screen: step 13, image 2 of 3 Kindle Touch Screen Replacement, Screen: step 13, image 3 of 3
    • Using your Metal Spudger, place the pointy end into the top of the clip.
    • Gently rotate the Spudger and lift the plastic unit to create a gap on the side.
  14. Kindle Touch Screen Replacement: step 14, image 1 of 2 Kindle Touch Screen Replacement: step 14, image 2 of 2
    • Use the Spudger in the gap to pry the clip open.
    • Repeat for the other clips.
  15. Kindle Touch Screen Replacement: step 15, image 1 of 3 Kindle Touch Screen Replacement: step 15, image 2 of 3 Kindle Touch Screen Replacement: step 15, image 3 of 3
    • With the clips separated, gently guide the Screen's Motherboard Connector through the hole.
Adam Yerly
1,933 Reputation
7 Guides authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
8 Guides authored
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 83
All Time: 9,564
