Kindle Touch Bezel Replacement
  1. Kindle Touch Bezel Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch Bezel Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch Bezel Replacement, Back Cover: step 1, image 3 of 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
  2. Kindle Touch Bezel Replacement: step 2, image 1 of 2 Kindle Touch Bezel Replacement: step 2, image 2 of 2
    • Gently lift the bottom and slide the panel off.
  3. Kindle Touch Bezel Replacement, Removing the screws to access the bezel.: step 3, image 1 of 2 Kindle Touch Bezel Replacement, Removing the screws to access the bezel.: step 3, image 2 of 2
    • Remove the six 4 mm screws in order to access the front plate. Use a Phillips #00 screwdriver.
  4. Kindle Touch Bezel Replacement, Bezel removal.: step 4, image 1 of 3 Kindle Touch Bezel Replacement, Bezel removal.: step 4, image 2 of 3 Kindle Touch Bezel Replacement, Bezel removal.: step 4, image 3 of 3
    • Use a plastic opening tool to pry the top three sides of the bezel. Since there is glue under the bezel, gently pivot the face at the bottom off the Kindle and slide the clips out.
    • The clips can be easily bent. Do not try to force the clips out. If you do bend some, they can be bent back.
Jerome Narine
221 Reputation
1 Guide authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
8 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 23
All Time: 3,013
