Kindle Touch 3G Card Housing Replacement
Video Overview
  1. Kindle Touch 3G Card Housing Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch 3G Card Housing Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch 3G Card Housing Replacement, Back Cover: step 1, image 3 of 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
  2. Kindle Touch 3G Card Housing Replacement: step 2, image 1 of 2 Kindle Touch 3G Card Housing Replacement: step 2, image 2 of 2
    • Gently lift the bottom and slide the panel off.
  3. Kindle Touch 3G Card Housing Replacement, Battery: step 3, image 1 of 3 Kindle Touch 3G Card Housing Replacement, Battery: step 3, image 2 of 3 Kindle Touch 3G Card Housing Replacement, Battery: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch 3G Card Housing Replacement: step 4, image 1 of 3 Kindle Touch 3G Card Housing Replacement: step 4, image 2 of 3 Kindle Touch 3G Card Housing Replacement: step 4, image 3 of 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch 3G Card Housing Replacement, 3G Card Housing: step 5, image 1 of 1
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver.
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
Adam Yerly
1,933 Reputation
7 Guides authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 46
All Time: 2,068
