Introduction
Next to the battery is the 3G unit. However, in the
models that are WiFi only, there will instead be a plastic placeholder instead. The replacement instructions for both are identical.
Video Overview
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
Slide the back panel downward, toward the charging port. This will release the clips on the top half.
Once the top clips release, gently lift the back panel away.
Remove the indicated four 2 mm screws with a Phillips #00 screwdriver.
Next, gently lift the 3G assembly with a Spudger or your fingers.
