Kindle 7th Generation Back Panel Replacement
  1. Kindle 7th Generation Back Panel Replacement, Front Panel: step 1, image 1 of 2 Kindle 7th Generation Back Panel Replacement, Front Panel: step 1, image 2 of 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Back Panel Replacement: step 2, image 1 of 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Kindle 7th Generation Back Panel Replacement, Back Panel: step 3, image 1 of 2 Kindle 7th Generation Back Panel Replacement, Back Panel: step 3, image 2 of 2
    • Remove the ten 5.0 mm Phillip Head screws with the Torx T5 screwdriver.
    • A magnetized screw mat can help you keep track of your screws.
  4. Kindle 7th Generation Back Panel Replacement: step 4, image 1 of 1
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
Abby Roulier
966 Reputation
3 Guides authored
Cal Poly, Team 6-28, Amido Winter 2015 Member of Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Members
18 Guides authored
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 58
All Time: 4,855
