Keychron K10 Max Wireless Keyboard PCB Replacement
    1. Keychron K10 Max Wireless Keyboard PCB Replacement, Keycap: step 1, image 1 of 3 Keychron K10 Max Wireless Keyboard PCB Replacement, Keycap: step 1, image 2 of 3 Keychron K10 Max Wireless Keyboard PCB Replacement, Keycap: step 1, image 3 of 3
      • Lay the keyboard face down on the workspace.
      • Use a 2.5 mm hex screwdriver to remove the eight 4.5 mm screws from the back case.
      • Carefully separate the front frame from the keyboard and set it aside.
      • There is a clear shield that sits right above the arrow keys. This shield is to diffuse the LEDs from the keyboard, and it can fall out easily. Just remember to put it back if it does when reassembly.
      Ask FixBot
    2. Keychron K10 Max Wireless Keyboard PCB Replacement: step 2, image 1 of 2 Keychron K10 Max Wireless Keyboard PCB Replacement: step 2, image 2 of 2
      • Slide the keycap puller over the keycap until it grips underneath.
      • Pull straight upward to remove the keycap.
      • Sometimes the mechanical switch itself comes with the keycap. Just remove the switch from the button and reinstall the switch.
      Ask FixBot
    1. Keychron K10 Max Wireless Keyboard PCB Replacement, Mechanical Key Switch: step 3, image 1 of 2 Keychron K10 Max Wireless Keyboard PCB Replacement, Mechanical Key Switch: step 3, image 2 of 2
      • Place the switch puller around the two small tabs on the front and back of the switch.
      • Squeeze the switch puller to release the tabs, then pull straight upward to remove the switch.
      • The photos show red mechanical switches, but your keyboard may have a different switch color. The removal process is the same for this style of hot-swappable mechanical switch.
      Ask FixBot
    2. Keychron K10 Max Wireless Keyboard PCB Replacement: step 4, image 1 of 3 Keychron K10 Max Wireless Keyboard PCB Replacement: step 4, image 2 of 3 Keychron K10 Max Wireless Keyboard PCB Replacement: step 4, image 3 of 3
      • The replacement switch is oriented to fit only one way.
      • Align the copper pins on the bottom of the switch with the socket.
      • Make sure the copper pins are aligned before pressing the switch into place. Installing the switch in the wrong orientation can bend or break the pins.
      • Press the switch straight down until it clicks into place.
      • The switch should sit flush with the surrounding switches and the keyboard frame.
      Ask FixBot
    1. Keychron K10 Max Wireless Keyboard PCB Replacement, Keyboard PCB: step 5, image 1 of 3 Keychron K10 Max Wireless Keyboard PCB Replacement, Keyboard PCB: step 5, image 2 of 3 Keychron K10 Max Wireless Keyboard PCB Replacement, Keyboard PCB: step 5, image 3 of 3
      • Remove all 108 keycaps and switches from the keyboard.
      • Use a Phillips #1 screwdriver to remove the thirteen 7.5 mm screws from the frame.
      • Flip the board over.
      Ask FixBot
    2. Keychron K10 Max Wireless Keyboard PCB Replacement: step 6, image 1 of 2 Keychron K10 Max Wireless Keyboard PCB Replacement: step 6, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the sixteen 4.5 mm gold screws on the back of the board.
      • These screws secure the protective foam and larger key stabilizer assemblies, such as Shift and Enter.
      Ask FixBot
    3. Keychron K10 Max Wireless Keyboard PCB Replacement: step 7, image 1 of 3 Keychron K10 Max Wireless Keyboard PCB Replacement: step 7, image 2 of 3 Keychron K10 Max Wireless Keyboard PCB Replacement: step 7, image 3 of 3
      • Remove the foam layers to fully expose the keyboard PCB.
      • Handle the PCB by the edges to avoid damaging components or contaminating the board.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 48
Past 30 Days: 125
All Time: 428
