Introduction
To get to the spring the K-cup assembly housing, the lid, and the water pump will need to be removed.
Using a Phillips #2 screwdriver unscrew two 2mm screws.
Once the screws are out, lift up and squeeze the k-cup assembly housing to take it out.
Using the Phillips #0 screwdriver unscrew two 2mm screws on the water pump.
Once unscrewed lift the water pump up and pull and twist it off.
