Keurig K40 Spring Replacement
  1. Keurig K40 Spring  Replacement, Spring: step 1, image 1 of 2 Keurig K40 Spring  Replacement, Spring: step 1, image 2 of 2
    • Using a Phillips #2 screwdriver unscrew two 2mm screws.
    • Once the screws are out, lift up and squeeze the k-cup assembly housing to take it out.
  2. Keurig K40 Spring  Replacement: step 2, image 1 of 1
    • Use the handle to open the lid then squeeze and move the lid around to take it off.
  3. Keurig K40 Spring  Replacement: step 3, image 1 of 3 Keurig K40 Spring  Replacement: step 3, image 2 of 3 Keurig K40 Spring  Replacement: step 3, image 3 of 3
    • Using the Phillips #0 screwdriver unscrew two 2mm screws on the water pump.
    • Once unscrewed lift the water pump up and pull and twist it off.
  4. Keurig K40 Spring  Replacement: step 4, image 1 of 2 Keurig K40 Spring  Replacement: step 4, image 2 of 2
    • Using the tweezer and the plastic opening tool grab the front of the spring to take it off.
Michelle Sanchez
165 Reputation
1 Guide authored
USF Tampa, Team 6-1, Eyestone Spring 2016 Member of USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 4,539
