Kenwood Chef: Replacing the SER1018 Planetary set
  1. Kenwood Chef: Replacing the SER1018 Planetary set, Remove the locking latch knob: step 1, image 1 of 1
    • Remove the button
    • Remove the white sheath
  2. Kenwood Chef: Replacing the SER1018 Planetary set, Remove the sun gear: step 2, image 1 of 2 Kenwood Chef: Replacing the SER1018 Planetary set, Remove the sun gear: step 2, image 2 of 2
    • Unscrew the hex nut
    • Remove the sun gear straight ahead.
    • Unscrew the Torx screws fixing the bottom of the housing to the machine
  3. Kenwood Chef: Replacing the SER1018 Planetary set, Bottom of the machine: step 3, image 1 of 2 Kenwood Chef: Replacing the SER1018 Planetary set, Bottom of the machine: step 3, image 2 of 2
    • Remove the bottom of the machine
    • The elastic seal can be removed for cleaning
    • Remove the felt pad
  4. Kenwood Chef: Replacing the SER1018 Planetary set, Fast and medium speed outputs: step 4, image 1 of 2 Kenwood Chef: Replacing the SER1018 Planetary set, Fast and medium speed outputs: step 4, image 2 of 2
    • Unscrew the screws on each side of the circular discs to remove the circular plastic discs
    • The discs and screws are different, be sure to take note of where they go
  5. Kenwood Chef: Replacing the SER1018 Planetary set, Housing cover: step 5, image 1 of 2 Kenwood Chef: Replacing the SER1018 Planetary set, Housing cover: step 5, image 2 of 2
    • Unscrew the three Torx screws
    • Lift the housing cover up and out of the machine.
    • Pay attention to the alignment of the white shock absorber and where it was when you removed the housing. (red mark)
  6. Kenwood Chef: Replacing the SER1018 Planetary set, The challenge: loosen the hidden screw: step 6, image 1 of 2 Kenwood Chef: Replacing the SER1018 Planetary set, The challenge: loosen the hidden screw: step 6, image 2 of 2
    • It is not necessary to proceed to the next step if the plastic drive wheel has been removed
    • According to "Jens" simply turn the plastic drive wheel in the opposite direction of the watch to remove it, while blocking the housing. "Julien" found a YouTube video that shows how to proceed. Start at 7:25. Big thanks to Jens and Julien.
    • It's very hard to loosen the Tx20 screw hidden by the plastic drive wheel. Beware of metal burrs that your finger may catch.
    • I did not manage to remove the drive wheel from its axis
    • Whoever takes the risk can make a hole in the wheel. I did not have the courage.
    • I made a special tool -> See next.
  7. Kenwood Chef: Replacing the SER1018 Planetary set, Special Tool: step 7, image 1 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Special Tool: step 7, image 2 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Special Tool: step 7, image 3 of 3
    • I modified an open end wrench to drive a Tx20 bit
    • A slot has been made to facilitate the reassembly of the screw
  8. Kenwood Chef: Replacing the SER1018 Planetary set, Open the housing: step 8, image 1 of 2 Kenwood Chef: Replacing the SER1018 Planetary set, Open the housing: step 8, image 2 of 2
    • Remove the guides (red mark). They can be reassembled after closing the housing
    • Remove the seal. I replaced it with silicone similar to what is used in the bathroom.
  9. Kenwood Chef: Replacing the SER1018 Planetary set, Planetary: step 9, image 1 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Planetary: step 9, image 2 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Planetary: step 9, image 3 of 3
    • The former one has a cross fromation.
    • The new one has a bayonet tool port. The beater and the whip are in the same position relative to the bowl.
    • The width of the toothed wheel does not seem to have any difference.
  10. Kenwood Chef: Replacing the SER1018 Planetary set, Training axis: step 10, image 1 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Training axis: step 10, image 2 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Training axis: step 10, image 3 of 3
    • The former one has a cross patteren
  11. Kenwood Chef: Replacing the SER1018 Planetary set, Labels: step 11, image 1 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Labels: step 11, image 2 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Labels: step 11, image 3 of 3
    • Cod. SER1018: Plastic bag containing the three spare parts
    • Planetary label
    • Hex nut: label and price
  12. Kenwood Chef: Replacing the SER1018 Planetary set, Fitting the gears: step 12, image 1 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Fitting the gears: step 12, image 2 of 3 Kenwood Chef: Replacing the SER1018 Planetary set, Fitting the gears: step 12, image 3 of 3
    • Place each gear on the axis
    • Be sure that the gear teeth line up!
  13. Kenwood Chef: Replacing the SER1018 Planetary set, Crank Case Assembly: step 13, image 1 of 2 Kenwood Chef: Replacing the SER1018 Planetary set, Crank Case Assembly: step 13, image 2 of 2
    • There is a lot of greasein the case. Spread the grease on the surfaces that need it.
    • Replace the seal. See step 8.
    • Set the machine up with the arm in a horizontal position. The shaft of the will fall if the arm is raised
    • Gently slide the two parts into each other.
    • The screws were loose during disassembly. I fixed them with a drop of screw fixation solution.
    • Reinsert the guides to the original positions
  14. Kenwood Chef: Replacing the SER1018 Planetary set, Hidden screw: step 14, image 1 of 1
    • Screw the hidden screw back in
    • Tighten with the special tool of step 7
To reassemble your device, follow these steps in reverse order.
10 other people completed this guide.
Special thanks to these translators:
fr en
100%
[deleted] is helping us fix the world! Want to contribute?
Start translating ›
Bruno M
872 Reputation
3 Guides authored
6 Comments
non mais les vieux ustensiles ne sont pas compatible avec le nouvelle axe
f g - Reply
Ce tutoriel est très utile pour démontrer un model similaire (le KM070)
Brendan - Reply
Merci c’est très utile. Pour enlever la vis T20 sous la roue d’entraînement j’ai utilisé une clé torx à angle droit du commerce. Pour la remonter un petit trou de 8 sur le dessus de la roue pour passer la clé sans rien affaiblir. Pour le joint je pense que le silicone n’est pas judicieux car on ne pourra plus le démonter . J’ai opté pour un mastic de plombier genre Gebajoint.
Jeannot la bricole - Reply
J'ai pris l'option de percer la grande roue crantée. J'y suis allez doucement et c'est ok pour enlever la vis
Bernard Frise - Reply
Past 24 Hours: 16
Past 7 Days: 83
Past 30 Days: 248
All Time: 20,765
