Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓The Nintendo Switch comes with two Joy-Con controllers. This guide will show you how to replace the joystick of the right Joy-Con. The procedure for repairing the left Joy-Con is different, so be sure to follow the correct set of instructions for your controller.
Please note that this repair does not have the same steps as the left Joy-Con. If you are looking to replace the left Joystick, please follow my other guide with the specific details.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Spudger4.9
Tool used on this step:Magnetic Project Mat$19.95
Remove the four tri-point Y00 screws from the back panel of the Joy-Con.
Insert an opening pick under the lower side of the back panel (opposite the R and ZR buttons).
Slide the flat edge of an opening pick up the side of the Joy-Con.
Open the Joy-Con like a book, with the charging rail facing away from you.
Use a spudger to gently pry the battery connector from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
Insert an opening pick between the battery and the Joy-Con housing. Gently pry out the battery, which is lightly taped in place.
Carefully de-thread the upper half of the grey antenna cable out of the battery cavity.
Pry up with the pointy end of a spudger to disconnect the antenna cable's coaxial connector from the motherboard.
Remove the grey antenna cable.
Tool used on this step:Tweezers$4.99
The ZR button cable in this Joy-Con is short and can be tricky to reconnect. You can skip this step and leave it connected, but be careful not to strain it.
If you choose to disconnect it:
The ZR button cable is locked in place by a small ZIF connector on the motherboard. Use tweezers or a spudger to flip up the ZIF connector lock.
Use tweezers to gently pull the ZR button flex cable out of the ZIF connector socket. The midframe is now disconnected and can be removed.
The joystick cable is also locked into place by a ZIF connector. Use tweezers or a spudger to flip the ZIF lock upward and carefully disconnect the cable.
Use your fingers to pull the thumbstick off of the Gulikit joystick module.
560 other people completed this guide.
71 Guide Comments
A good guide though for the antenna instead of disconnecting the cable it would be easier to simply slide out the plate and wire from the side of the battery tray
The antenna and battery don’t need to be disconnected, you can easily move them out of the way.
When reassembling, reconnecting the ribbon cable for the RL button is fiddly, easier if you can avoid disconnecting it as well. Just rotate the plastic battery plate a quarter turn counterclockwise to get it out of the way and access the analog stick.
You can test the controller immediately after seating the joystick to make sure the ribbon cable is properly connected.
In agreement with the others, antenna definitely doesn’t need to be removed. Also noticed that the Y000 bit worked a lot better than the Y00 for the outside screws.
Hello I have followed the guide succesfully for the most part, however the joy con doesn’t seem to power up after reconnecting the battery and the anthenna. I even tried swapping the batteries between joy- cons and battery from the right one does work in the left one. The right joy con doesn’t turn on even with the other battery inserted. Any ideas?
