Introduction
The motherboard is the brain of the Jabra Evolve2 65. If this part were to get damaged, the whole functionality of the headphones would be hindered. If you've tried the troubleshooting guides and other repairs but are still having issues with the headphones, a bad motherboard could be the cause.
Listed below are the steps to remove and replace the motherboard. The disassembly itself is relatively straightforward, and by the end of this guide you will know how to access and replace the motherboard on your Jabra Evolve2 65 headphones.
This guide requires soldering. If you're unfamiliar with soldering, review the How to Solder and Desolder Connections guide and take appropriate precautions before beginning.
Peel back the tape where the microphone's base connects to the headband.
Use a T6 Torx screwdriver to remove the single 2 mm screw.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
