JVC GR-D290U LCD Screen Replacement
  1. JVC GR-D290U LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Set up a clean work space with an organization system for all necessary screws.
    • Make sure all tools are present before starting (as listed above).
  2. JVC GR-D290U LCD Screen Replacement: step 2, image 1 of 1
    • Remove camera battery. (Not shown.)
    • Remove 2 screws connecting back plate to camera base.
  3. JVC GR-D290U LCD Screen Replacement: step 3, image 1 of 1
    • Remove 2 screws on side opposite LCD screen.
  4. JVC GR-D290U LCD Screen Replacement: step 4, image 1 of 1
    • Note: Open LCD screen for better access to screw. Reclose screen when finished.
    • Lift up dark gray tab on LCD side of camera and move it aside.
    • Remove screw under dark gray tab and then replace tab.
  5. JVC GR-D290U LCD Screen Replacement: step 5, image 1 of 2 JVC GR-D290U LCD Screen Replacement: step 5, image 2 of 2
    • Place a plastic opening tool under seam of camera top cover and unsnap cover.
    • Pull top cover off camera base and set aside.
  6. JVC GR-D290U LCD Screen Replacement: step 6, image 1 of 2 JVC GR-D290U LCD Screen Replacement: step 6, image 2 of 2
    • Remove 2 screws underneath top cover on LCD side of camera.
  7. JVC GR-D290U LCD Screen Replacement: step 7, image 1 of 1
    • Remove 5 screws indicated on bottom plate of camera.
  8. JVC GR-D290U LCD Screen Replacement: step 8, image 1 of 2 JVC GR-D290U LCD Screen Replacement: step 8, image 2 of 2
    • Open LCD screen and remove 2 screws at hinge of screen.
    • Remove plastic hinge cover from camera base.
    • Close LCD screen when finished.
  9. JVC GR-D290U LCD Screen Replacement: step 9, image 1 of 2 JVC GR-D290U LCD Screen Replacement: step 9, image 2 of 2
    • Warning: Avoid unattaching internal wiring by prying camera apart slowly and carefully.
    • Start from bottom of camera. Press and hold eject button with one hand.
    • Use other hand to pry LCD screen cover from base. Leave labeled side closed.
  10. JVC GR-D290U LCD Screen Replacement: step 10, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 10, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 10, image 3 of 3
    • Unattach white tab from LCD screen side of camera by gently tugging at base of tab.
    • Put larger camera base aside.
  11. JVC GR-D290U LCD Screen Replacement: step 11, image 1 of 1
    • Remove 3 screws holding LCD screen hinge to base.
  12. JVC GR-D290U LCD Screen Replacement: step 12, image 1 of 1
    • Remove 2 screws on green circuit board.
  13. JVC GR-D290U LCD Screen Replacement: step 13, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 13, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 13, image 3 of 3
    • Warning: Orange band must stay attached to circuit board at all times.
    • Remove L-shaped metal piece from upper left-hand corner of circuit board.
    • Remove circuit board from cover piece and move aside with orange band intact.
  14. JVC GR-D290U LCD Screen Replacement: step 14, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 14, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 14, image 3 of 3
    • Open LCD screen and carefully pull circuit board through empty hinge space.
    • Set aside larger LCD panel.
  15. JVC GR-D290U LCD Screen Replacement: step 15, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 15, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 15, image 3 of 3
    • Remove 2 screws on hinge side of LCD screen.
    • Remove screw at side of LCD screen.
    • Pull open with plastic opening tool and pry apart.
  16. JVC GR-D290U LCD Screen Replacement: step 16, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 16, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 16, image 3 of 3
    • Remove screw in circuit board.
    • Pull LCD screen pack from frame with circuit board on top.
    • Unattach LCD screen by firmly grasping copper tab and gently tugging until latch unsnaps.
  17. JVC GR-D290U LCD Screen Replacement: step 17, image 1 of 2 JVC GR-D290U LCD Screen Replacement: step 17, image 2 of 2
    • Connect new LCD screen by fitting in the copper attachment site to the thin, black clasp on the circuit board.
    • Fold over black clasp and snap into place.
    • Note: You may need to use the plastic opening tool to snap thin black clasp into place.
  18. JVC GR-D290U LCD Screen Replacement: step 18, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 18, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 18, image 3 of 3
    • Put LCD screen into the silver frame and make sure it lies flat. It should line up with two white, plastic brackets.
    • Place the black film frame lined up with the white film into the silver frame.Both should be held in place by tabs.
    • Place the circuit board over the film layers.
    • Double-check that the LCD screen lies flat in its frame and reinsert the circuit board screw.
  19. JVC GR-D290U LCD Screen Replacement: step 19, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 19, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 19, image 3 of 3
    • Before reattaching LCD screen lid, make sure the silver hinge piece is inserted in slot next to circuit board.
    • Replace loose orange band in slot on hinge side of LCD screen.
    • Snap LCD screen lid back in place starting at side opposite hinge.
  20. JVC GR-D290U LCD Screen Replacement: step 20, image 1 of 2 JVC GR-D290U LCD Screen Replacement: step 20, image 2 of 2
    • Reinsert shortest of 3 screws on top of screen cover opposite of hinge.
    • Reinsert 2 screws on hinge side of LCD screen.
  21. JVC GR-D290U LCD Screen Replacement: step 21, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 21, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 21, image 3 of 3
    • Place loose circuit board back through empty hinge space.
    • Line up LCD screen in slot on camera base and snap into place.
    • Reinsert 3 screws along orange band to hold LCD screen to entire panel.
  22. JVC GR-D290U LCD Screen Replacement: step 22, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 22, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 22, image 3 of 3
    • Reinsert circuit board in slot. Make sure to lock securely under tabs.
    • Reinsert L-shaped metal piece in slot. Line up with screw hole and protruding place holder.
    • Reinsert 2 screws in circuit board with the longer screw holding the L-shaped metal piece in place.
  23. JVC GR-D290U LCD Screen Replacement: step 23, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 23, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 23, image 3 of 3
    • Reattach white tab by placing under thin, black slot and snapping back into place.
    • Carefully line up bottom of LCD panel and camera base and snap back into place.
  24. JVC GR-D290U LCD Screen Replacement: step 24, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 24, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 24, image 3 of 3
    • Reinsert LCD screen hinge and 2 screws holding it in place.
    • Reinsert 5 screws on bottom panel of camera. The shortest screw needs to be put into the hole with the arrow pointing to it.
  25. JVC GR-D290U LCD Screen Replacement: step 25, image 1 of 3 JVC GR-D290U LCD Screen Replacement: step 25, image 2 of 3 JVC GR-D290U LCD Screen Replacement: step 25, image 3 of 3
    • Reinsert 2 screws under top cover of LCD side of camera.
    • Move dark grey tab to ensure that top cover is not damaged.
    • Line up top cover on camera base and snap it back into place.
  26. JVC GR-D290U LCD Screen Replacement: step 26, image 1 of 2 JVC GR-D290U LCD Screen Replacement: step 26, image 2 of 2
    • Reinsert screw under dark, grey tab on the LCD side of camera and replace tab.
    • Reinsert 2 screws on side opposite LCD side of camera.
  27. JVC GR-D290U LCD Screen Replacement: step 27, image 1 of 1
    • Reinsert 2 screws connecting back plate to camera base.
    • Reinsert battery.
    • Turn on and test functionality.
justin chen
47 Reputation
3 Guides authored
Cal Poly, Team 18-69, Johann Spring 2010 Member of Cal Poly, Team 18-69, Johann Spring 2010
CPSU-JOHANN-S10S18G69
4 Members
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 34
All Time: 4,796
