JBL Go 4 Outer Shell Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
43
Past 30 Days:
192
All Time:
1,394
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 - 5 minutes
Difficulty: Very easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
In this Replacement Guide, you will find the steps and process to replace the Outer Shell of the JBL Go 4.
The shell or case protects the device from accidents such as drops, slips, or slides, helping to keep the internal structures intact. The shell also provides a level of waterproofing for the device, while it's not the main waterproofing, it helps to keep things out.
If the shell becomes damaged, the quality of the speakers output can be hurt as well as the visual aesthetics.
Note: The device used in this guide is a non-genuine model, so the internal components may look different from those in your authentic device. However, the replacement procedure remains roughly the same and should still apply to your device.
Parts
Tools
    1. JBL Go 4 Outer Shell Replacement, Outer Shell: step 1, image 1 of 3 JBL Go 4 Outer Shell Replacement, Outer Shell: step 1, image 2 of 3 JBL Go 4 Outer Shell Replacement, Outer Shell: step 1, image 3 of 3
      • Remove the speaker's grille by inserting the tip of an opening tool into the top corner, opposite the strap.
      • Slide the tool along the edge of the housing until it pops off. Place it to the side.
      • Be sure that the battery has been drained completely before attempting this replacement.
      Ask FixBot
    2. JBL Go 4 Outer Shell Replacement: step 2, image 1 of 3 JBL Go 4 Outer Shell Replacement: step 2, image 2 of 3 JBL Go 4 Outer Shell Replacement: step 2, image 3 of 3
      • Insert the same opening tool in the opposite corner, lifting carefully.
      • Slide the tool along the edge until the cover pops off.
      • Gently pull the housing up and to the side.
      • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
      Ask FixBot
    3. JBL Go 4 Outer Shell Replacement: step 3, image 1 of 1
      • At this point, you should switch over to the JBL Go 4 Battery Replacement, and follow the steps to remove the battery
      • Once the battery is removed, use a strong adhesive to adhere it to the new shell and follow the steps in reverse.
      Ask FixBot
Jackosn Caron
255 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 43
Past 30 Days: 192
All Time: 1,394
