JBL Go 4 Battery Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
15
Past 7 Days:
71
Past 30 Days:
288
All Time:
2,365
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In this Replacement Guide, you will find the steps and process to replace the battery in the JBL Go 4.
The Battery provides power to the entire device. A failing battery can have reduced battery life or none at all, it can also begin to overheat or shut down at random times.
Before using this guide, make sure to review the troubleshooting page—oftentimes, there can be other reasons for shortened battery life.
Note: The device used in this guide is a non-genuine model, so the internal components may look different from those in your authentic device. However, the replacement procedure remains roughly the same and should still apply to your device.
Parts
Tools
    1. JBL Go 4 Battery Replacement, Battery: step 1, image 1 of 3 JBL Go 4 Battery Replacement, Battery: step 1, image 2 of 3 JBL Go 4 Battery Replacement, Battery: step 1, image 3 of 3
      • Insert an opening tool into the seam in between the grille and chassis, in the top corner opposite the strap.
      • Slide the tool along the edge of the housing until the grille releases.
      • Remove the grille.
      • Be sure that the battery has been drained completely before attempting this replacement.
      Ask FixBot
    2. JBL Go 4 Battery Replacement: step 2, image 1 of 3 JBL Go 4 Battery Replacement: step 2, image 2 of 3 JBL Go 4 Battery Replacement: step 2, image 3 of 3
      • Insert an opening tool in the opposite corner, lifting carefully.
      • Slide the tool along the edge until the cover pops off.
      • Gently pull the housing up and to the side.
      • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
      Ask FixBot
    3. JBL Go 4 Battery Replacement: step 3, image 1 of 2 JBL Go 4 Battery Replacement: step 3, image 2 of 2
      • Find the connection between the motherboard and the battery cable as labeled.
      • Gently depress the plastic tabs and slowly wiggle the connector until it comes free.
      • Be incredibly gentle with this connector as any excessive force can damage the motherboard.
      Ask FixBot
    4. JBL Go 4 Battery Replacement: step 4, image 1 of 2 JBL Go 4 Battery Replacement: step 4, image 2 of 2
      • Insert an opening tool beneath the battery, on the side opposite to the battery cable.
      • Using a lever motion, pry the battery out slowly, sliding it further under to break the adhesive up.
      • It's important to note that the battery is held on with a small adhesive pad, so more force than should feel necessary will be needed.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jackosn Caron
255 Reputation
2 Guides authored
2 Guide Comments
Great guide, thanks! Small point -
Typo - “Insert an opening into the seam”. I think you’re missing ‘tool’.
Alexander Dyas - Reply Share
Thanks for pointing that out, @alexanderdyas. We took care of the typo. In the future, feel free to go ahead and make the edit!
Connor Bassolino - Reply Share
Past 24 Hours: 15
Past 7 Days: 71
Past 30 Days: 288
All Time: 2,365
