JBL Go 3 Motherboard Replacement
  1. JBL Go 3 Motherboard Replacement, Grille: step 1, image 1 of 3 JBL Go 3 Motherboard Replacement, Grille: step 1, image 2 of 3 JBL Go 3 Motherboard Replacement, Grille: step 1, image 3 of 3
    • Using an iFixit Opening Pick or a Jimmy, pry along the seam between the rubber outer layer and the hard shell.
    • Work your way around the edges until the shell loosens and can be fully removed.
  2. JBL Go 3 Motherboard Replacement: step 2, image 1 of 3 JBL Go 3 Motherboard Replacement: step 2, image 2 of 3 JBL Go 3 Motherboard Replacement: step 2, image 3 of 3
    • Once the shell is loosened on all sides, gently lift and remove it completely.
    • Align the new shell with the speaker’s body, making sure all edges are properly positioned.
    • Press firmly around the edges until the shell snaps securely into place.
  3. JBL Go 3 Motherboard Replacement, Motherboard: step 3, image 1 of 2 JBL Go 3 Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Locate the internal screws underneath the outer shell.
    • Use your precision screwdriver to remove all screws securing the plastic enclosure.
    • Carefully lift the casing to expose the motherboard and other internal components.
  4. JBL Go 3 Motherboard Replacement: step 4, image 1 of 2 JBL Go 3 Motherboard Replacement: step 4, image 2 of 2
    • Unscrew the motherboard to the internal casing of the speaker.
    • Unscrew the speaker attached to the casing as well.
    • The speaker and part of the battery may be soldered onto the motherboard, proceed with caution when removing attachments
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kasey Oliver
507 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 172
