JBL Go 3 Driver Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
18
Past 7 Days:
55
Past 30 Days:
228
All Time:
1,487
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This guide walks you through replacing the main speaker driver in a JBL Go 3. This may be necessary if your speaker is producing distorted sound, no audio, or rattling noises. Be prepared to handle delicate internal components and possibly perform some soldering.
Tools
    1. JBL Go 3 Driver Replacement, Driver: step 1, image 1 of 2 JBL Go 3 Driver Replacement, Driver: step 1, image 2 of 2
      • Hold the power button until the JBL Go 3 shuts off
      • Disconnect any charging cables
      • Use jimmy to remove the hard shell
      • Work your way around the edges slowly—be patient as it's glued or snapped in tightly
      Ask FixBot
    2. JBL Go 3 Driver Replacement: step 2, image 1 of 3 JBL Go 3 Driver Replacement: step 2, image 2 of 3 JBL Go 3 Driver Replacement: step 2, image 3 of 3
      • Once the hard shell is removed,use jimmy to lift up the speaker part.
      • Locate the internal screws underneath the outer shell.
      • Use your precision screwdriver to remove all screws securing the plastic enclosure.
      • Carefully lift the casing to expose the speaker and other internal components.
      Ask FixBot
    3. JBL Go 3 Driver Replacement: step 3, image 1 of 2 JBL Go 3 Driver Replacement: step 3, image 2 of 2
      • If accessible, unplug the battery to prevent any electrical short while working.
      • If it's soldered, proceed carefully and avoid touching metal contacts unnecessarily.
      • Unscrew any fasteners holding the speaker in place.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kasey Oliver
507 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 55
Past 30 Days: 228
All Time: 1,487
